Scat arp 2000 rod bolts
o1heavy
1974 dart sport
tarkington
This has turned into a real pain
But does anyone know the torque specs
On the arp 2000 rod bolt used with the scat rotating assembly ?? 360/408
The arp website is not very helpful
I may be over looking it ,
But tired of digging for it ,
I be over looking it ,
But tiired of digging for it ,
Call them. Then call the ROD Manufacturer. I've got an old set of Forged pistons in my Harley from the 70s... the ring manufacturer had one Gap in mind, the book says another, be all end all, the Piston Manufacturers who I went with because they know the metals expansion rates
What size bolts ?
7/16 is 75 pounds with their lube.
3/8 is 45 pounds with their lube
You find that one the website??
No, just asking...factory tq specs for factory parts.... anything else, manufacturer has the final say... in my humble opinion. You only get one chance with a bottom end...one the pan goes on and she drops in the car and gets fired up, it best be right!
I know the pan is on and I almost sit it in the car
I looked on the arp website and all the bolts
Offered for a 360 where torqued 50 foot pounds so I went with ,
Then got to thinking ..
So here I am
This is from a box that had steel mopar sized small block i-beams.
I didn’t measure the length but according to that it will be 63 or 70 ft lbs
Cool thanks
Pan is coming back off ..
Better Now, than Later with a rod sticking outta it!
Been there terrible feeling
I had to put half groove
Mains back in this go around vs the full groove mains I had in this thing for last couple hundred passes , that kinda makes me nervous
I'm all for the cheap insurance of Fully Grooved Mains! Ain't bolted anything together without em.... and they work.
New arrival, Scat H-beam rods with ARP 2000 bolts for small bock Chrysler. It has a chart with same numbers as post 16, plus they added the L19 values.
