Schumacher Header Bolts?
jeeper
Klamath County, Oregon
Hello,
I am making some progress on the car and should be installing the engine in the next week if not sooner.
I removed all the studs on the exhaust just to avoid any future issues.
It looks like I can use standard bolts when installing the headers. Can I use off the shelf bolts that you get at a bolt company? Or do I need header specific ones?
I noticed that many aftermarket bolts are .750 long, my concern is that those are too short.
I am most concerned with getting something that is not too bad to install with the engine in the car.
Thank you for your help.
ROB
Summit gave me the wrong size (3/8"), so I went and bought some 8 grade at ACE. that were an 1" long. All but two fit for me. SO I called Summit, and they are sending the correct ones, but they are 3/4".
It seems either will do. 3/4 will fit better in tight spaces.
