schumachers headers
Pentastar 01
usa
anyone running schumachers tri y headers have a pic underneth your car to see how the exhaust is running an where abouts the flange sits?
seems my collector (flange) is hitting the torsion bar so far only got to drivers side
No picture right now. Mine does not hit using Schumacher mounts. Made my own exhaust to keep the heat away from the transmission.
Don’t know if this helps but here is pictures of my tri-y headers
Not the best shot, but it's all I had at the moment. You can barely see the flanges in the bottom left and right corners. Mine is 400 block in '67 Barracuda
I have a factory BB 67 Dart and it’s a 4 speed. The tri-y headers drivers side will not fit unless it is modified for a BB 4 speed car
Mine are tight also just enough room, did mine with a slant k frame wish I made them just a bit higher when cutting the ears.
these tri y were used/unused maybe for a older or base model?? mane is a 72 I am used transdapt mounts.. i am going to try heat em uo and try to bend them over??!!
these are messed up I sliced half the pipes bent em over put a 1/4 gap in the slice and still touching... so much for drop in headers I be welding on en tomorrow
