Sea Ray questions.
General Discussion
  1. Cope
    Cope Fusing with fire
    3,508
    3891
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    6:07 PM
    I'm going to look at this on Sunday and wonder if folks have an idea about known issues or problem areas with these?
    Mostly the I.O. and engine. The V6 seems a little small for such a large boat and I've never owned a I.O. drive. (I grew up around race boats)
    1987 SeaRay Mid Cabin 21'
    Thanks for the advice.
  2. diymirage
    diymirage HP@idle > hondaHP@redline
    15,708
    8254
    Oct 12, 2012
    michigan
    Local Time:
    7:07 PM
    looks great for an 87
    i would make sure you have them hook up the hose for dry testing the engine
    this will show you if the boat has always been properly winterized and your not leaking water anywhere (that is presuming this is a lake water cooled engine, and not a self contained system like in a car)
    • Agree Agree x 1
    • 4spdragtop
      4spdragtop FABO Gold Member FABO Gold Member
      26,102
      5637
      Aug 28, 2009
      Ontario
      Local Time:
      6:07 PM
      Looks to be a nice boat! I'm not well versed in boats, but check the gasket/boot from outdrive to boat. I looked at a boat that it was torn and was quoted around $800 to install one?
      I would say V6 is plenty big enough if it was maintained properly. Check for service records.
    • doogievlg
      doogievlg Well-Known Member
      7,081
      2110
      Nov 13, 2007
      Amelia, Ohio
      Local Time:
      7:07 PM
      I could be wrong but I am fairly certain that has a wood floor in it.
      I’ve been through that once and I will never put up with it again. I am not a professional carpenter but I have done a fair amount of wood working and that floor was awful.
      As far as the engine goes. The v6 is fine for that boat just because you are not getting a boat like that for skiing or speed.
      Take the boat out on the water for at least an hour. Turn it on and off a lot and really feel for any changes in rpm when cruising.
      • Agree Agree x 1
      • Krooser
        Krooser Reform School Graduate
        1,393
        1052
        Jul 19, 2015
        Land of Cheese
        Local Time:
        6:07 PM
        That boat looks like it has been well cared for and stored inside...
        • Agree Agree x 2
        • fishmens67
          fishmens67 Well-Known Member
          5,853
          2717
          Nov 10, 2012
          idaho
          Local Time:
          6:07 PM
          Be prepared for a lot of maintenance and unforeseen future parts failure no matter what boat you buy.
          maintenance is your best defense when owning a boat.
          I think the boat is well maintained and worth the investment. take a look !
        • JDMopar
          JDMopar Well-Known Member
          2,003
          818
          Jan 19, 2012
          Candler, NC/Myrtle Beach, SC
          Local Time:
          7:07 PM
          Back in that boats day, the V6 of choice for boat mfg's was usually the GM 4.3 My wife had a 17' Javelin ski boat when we got married, and it had the 4.3 V6 in it. It was plenty of giddy up - go for that boat, but I'm sure it weighed considerably less than the one you're looking at. We never had a minutes trouble out of it, other than the starter solenoid took a dump. Boat place wanted a hundred bucks for one, and I went to the NAPA store and got one for an S10 truck for like $14. Exact same part, and was on the boat when we sold it. That boat you're looking at looks to have been taken care of and sat inside when not in the water. About any boat is just a hole in the water to throw money into, but they can be a lot of fun. We have 2 smaller holes in the water to throw money in now.....a couple of old Kawasaki 900 Jet Skis. But.....I've never seen a hearse that looked like an armored car! If you get it, enjoy it! :D
        • Cope
          3,508
          3891
          Oct 20, 2009
          San Jose, Ca.
          Local Time:
          6:07 PM
          I'm actually very familiar with boats. I own a Catalina 25 and grew up racing a flat bottom jet.
          This will just be a fun day cruzer.
          I just never had an I.O. drive.
          I'll let ya know, if it looks as good in person I'll probably end with with a mother hole in the water to throw money into....
          • Like Like x 1
          • doogievlg
            7,081
            2110
            Nov 13, 2007
            Amelia, Ohio
            Local Time:
            7:07 PM
            My buddy bought a formula with an i.o. Motor last year. Ran great during the test drive then took a dump on us on the Ohio river and we were down stream of the ramp. We ended up replacing the fuel pump and it ran great then it started to overheat. Chased it down to being the sea water pump and it was destroyed. We got that replaced and it’s run good ever since but that was my one nightmare stories after being around boats for 27 years.
          • mycuda
            mycuda FABO Gold Member FABO Gold Member
            5,104
            2419
            Feb 15, 2011
            Chicago/ Metro
            Local Time:
            6:07 PM
            Sea Ray good overall boat. Everything up in up all good.
            Bayliner.... forget it.
            • Agree Agree x 1
            • magnumdart
              magnumdart You in a heap of trouble boy. FABO Gold Member
              3,868
              1190
              Dec 21, 2006
              Rogers, Arkansas
              Local Time:
              6:07 PM
              We had one, a little older, of that size we used for salmon fishing in Lake Michigan. Ford 302 for power. It was extremely dependable. Gas tank sprung a leak, it caught fire in the bilge. I dipped a five gallon bucket into the lake, tossed it over the entire fire and miracle of miracles it went out.
              I'd say a well maintained boat like that is well worth it.
              Biggest drawback to that is the trailer, IMO.
              It looks to be not even half the trailer that boat should have. I would at least double check it, before I pulled it too far.
            • SSVDP
              SSVDP FABO Gold Member FABO Gold Member
              4,364
              4259
              Feb 6, 2009
              Clarksville, Tn
              Local Time:
              7:07 PM
              I don’t think you can go too wrong with that. It’s all about the condition and that one looks well taken care of. Sea Ray is probably the best brand to buy.
              The I/O units in my experience work well but anything with an engine or boobs is trouble sooner or later.
              As mentioned a good trailer is important, check the wheel bearings, it looks like it has bearing buddies which is good.
              Budget a lot more than the purchase price for gas & small repairs/upgrades plus food & drinks.
              Get a weather radio and severe weather app for your phone.
              Then there’s the weird effect on ladies when you take them on the water so you need to be prepared for that too.
              • Like Like x 2
              • Cope
                3,508
                3891
                Oct 20, 2009
                San Jose, Ca.
                Local Time:
                6:07 PM
                Its mine, 5,500.00
                All new canvas last year, current tags and its CLEAN.
                stored inside for the last 12 years.
                New GPS fish finder sonar, not even out of the box.
                This guy took great care of her. 360 hours on the gauge, all original.
                Zero oil in the bilge and clean as a whistle.
                The only issue I could see is the blige blower is a little rusty (sounds funky) and I will have the out drive serviced. Just cus I dont want any issues with things I know nothing about.
                Thursday she will be on the water and in a slip.
                She gonna be tons of fun for me, my sis and the girls. I grew up boating and look forward to sharing that experience with my sisters girls!
                Next on the list is a Hondo.... when they get older really show em what boats are for!
                Thanks for all the advice!
                • Like Like x 2
                • SSVDP
                  4,364
                  4259
                  Feb 6, 2009
                  Clarksville, Tn
                  Local Time:
                  7:07 PM
                  Awesome!
                • Daves69
                  Daves69 FABO Gold Member FABO Gold Member
                  4,228
                  2254
                  Feb 20, 2011
                  WestOfChi
                  Local Time:
                  6:07 PM
                  Congrats! Looks good!
                  Sea Ray one of the high end boats. You might check for any soft wood in the stringers (if used on that model) or spongy floor areas and transom cracks. The 6 should be just fine if running right and the tabs will help. Docking it in windy conditions could be interesting.
                  My 19' - 190 HP boat will go 50+ with the 2bbl on flat water. The V-6 in mine makes it a little heavy in the ass so I have to watch the shallows.
                  Maybe a helpful link.....
                  Choose Schematics - Marine Parts Express
                  • Like Like x 2
