Searching for 340 build of my 65 dart
Mopar77
Member
Winter Park
Hey everyone, I am in search to purchase a 340/360 complete with auto trans or manual for my 65 dart that comes with slant 6 or any v8 if you have any that I can just drop in. I already have couple different K members to use.
Any help would be appreicated
Are you saying that you need an engine and the componants to convert a /6 to a v8?
The 340 engines are quite rare anymore and expensive.
The 360 engines are fairly common and just as good for
a normal street/strip car application of 400/450HP or even
a little more than that.
My kids 68 Valiant 360 is very streetable and runs in the 10's exactly the way
he drives it on the street. Many of you have seen it at Mopars at
the Strip for many years or read about it when it was Hot Rod cover car
years ago.
The money you save going with the 360 will help you buy a good set of
cylinder heads and intake which is from where a lot of the horsepower
is generated.
Too bad you are that far away. I have almost everything here that you will need.
The only K frame you need is the ine you currently have in the car which is the same for a slant or 64-66 273. 318 might use the same motor mounts as the 64-66 273 - can’t remember. 340/360mounts do need a bit of modification to work
