Seat belt location {67 BARRACUDA}
Zman1
Member
Gulf Shores,Al.
1967 BARRACUDA NOTCHBACK .
Looking for a little help with the proper locations of these seat belts. When purchased the carpet was removed .Found these belts in the trunk. I done some searching , still can not find a good pic. of the belts. Looks like I must be short a pair . If someone can help in proper location , I would appreciate the help . Then I can try to find the pair that is missing.
Number 1: Rear Outboard
Number 2: Front Inboard (not sure if rear inboard are the same)
Number 3: Front Outboard
Alan
Thanks Alan; That's the way I had #2 and 3 . But #3 kept rubbing the seat bracket. Note ; I don't have the correct bolts , must have to swivel to keep it from happening. THANKS AGAIN , now all I need is the rear inboards...
