Seat Track
RagTopTime
Member
Albany, NY
Does anyone know where I can find the plastic spacer(wedge) that goes in the seat track of the front bucket seats. It takes up the sloppiness between the 2 tracks. Thanks
That sounds like the plastic bearing housing for the seat tracks, if I'm understanding you correctly...
It should look something like this ??
Where can you get replacements...???? I need some for my bucket seats.
I've never seen replacements, but you could get a set of bench seat tracks cheap and pull the bearing housings to use on your buckets :)
Also, the earlier tracks used a metal housing instead of plastic and I'm pretty sure they interchange....
Thanks. Much appreciated.
I guess it's time to go on the hunt....
Since another owner returned the metal roller cages to me claiming they wouldn't fit to replace his broken plastic, there may be change in the tracks that I'm not aware of.
I'll never offer up the metal ones to replace plastic again. Good luck
The main point of my post was that the bearing housings could be found in the bench seat tracks for less $$....I thought the metal & plastic ones interchanged, but you might be right too Redfish :)
I'll look into it when I have time...Thanks
The metal ones have replaced the plastic in some cases. Failure in that one case led me to caution. I don't expect to ever have examples of the various year models or ever define the differences.
Question..?? If they make these..!! Where do they get the roller guides from..???
I know.... $64.00 question...LOL
China....LOL :)
I've never seen a set of the repro seat tracks in person, so who knows if they're even the same design??
A Chrysler dealer may be able to find that part in stock somewhere.
Seems the Chinese only reproduce per the OEM samples provided to them. They rarely change, redesign, improve anything.
At one time I needed the foot piece alone for a right door mirror. The entire mirror is available reproduction but a single piece of the assembly is/was not available.
Good luck
