seat tracks
Challenger
hallsville mo
need help does anyone have pictures of seat tracks for 69 dart buckets on or off seat -had mine restored dont know if there right ones need to see a track and distance between width of floor stud thanks
can any one help - having problems with seat track mounted buckets back in factory hole in floor driver seat slide lever hits seat belt and PUSHES to rear to slide and pass seat PUSHES to the front to slide and left side of pass seat tight aganist the trans tunnel help please
Where the trans tunnel begins at the firewall it is about 2.5 inches offset to the right. The right seat will run very closer to the hump.
The seat tracks are not left hand or right hand, just inboard and outboard. One release lever will function opposite the other.
This shows up again in the release cable from inboard to outboard tracks. One cable is tethered to the front of the seat frame , the other is tethered to the rear of the seat frame.
finally the floor studs are a square pattern. 14 or 16 inches, I forget.
Sorry I dont have pics. Hope this helps.
