Sebring seat belts?
Freezerman
MN
When using Sebring convert seats do you need to use the electric belt locks or do they have inertia locks also?
I took all the seat wiring out of the donor car including the inertia switch. It has to be used.
Ok, great. Thanks. Trying to decide if I should try that route or get 3 point retractable and put in
The seat control module in the Sebring performs several functions in addition to acting as an inertia switch. A seat transplant doesn't use most of them, so if you don't have the module a simple mercury switch could be used to lock the belts.
Thanks for that idea, I could modify a couple old thermostats I suppose.
