Seized throttle shafts in 4150
The end result may be worse than a worn throttle shaft if that sucker is seized that bad.
Success!!
I ended up soaking it in CLR for about a hour and a half, washed it with water and followed RRR advice and started tapping it with a hammer back and forth adding WD-40 and it started to move and after about 15min they were out!
Thank you for all your help and opinions.
Mike.
Success!!
Mike.
RRR is pretty tricky.
