slantsixdan
Here's a speedometer calibrated all the way to 200 for '68-'76 Valiant, '70-'76 Duster, '72-'76 Dart, '72 Demon, and '73-'76 Dart Sport. May also fit '67 Valiant. This is the export speedometer, meant for use in countries that use kilometres instead of miles. If you live in Canada, swapping this in will cure your math habit. It does not say "km" on the face, though, so if you live in the States and want your speedo to read up to 200 miles per hour, a speedo drive pinion with 1.6× the tooth count of your present pinion, or a ratio box from a speedo shop (such as DeLuxe Speedometer) will get that job done.
This speedo is brand new in the box, showing only the 1.6 km (= 1 mile) rolled up in final testing and calibration as the final stage of manufacture. It comes with the three light tube sleeves (left turn, right turn, high beam indicators) and the postage-paid postcard to notify Chrysler that you've swapped the odometer on a car.
$76 plus postage from Seattle, Washington, USA.
