selecting fuel line
72ScampTramp
Scamp Tramp
Fort Dodge Iowa
I'm in the process of selecting fuel line for my Scamp. Choices are pre-bent for around $100 shipped. Or Steel braided for about $4 a foot. Rubber fuel SAE J30R7 approved fuel line $20. or buying a coil for $20 then the tools to bend my own?
Im leaning towards the rubber I feel it its good enough for newer cars and fuel injection it should be ok for the Scamp. Plus at a reduced cost since the other options push the bill close to or over $100. What are the draw backs to running a rubber fuel line if any?
i would not use rubber all the way... all it takes is a rock to cut it goin down the road...
at least use the steel braided if not steel or aluminum line (30 bucks for 25ft roll)...
I wouldnt run alum on a street car... Steel is my second choice however I dont own the tools to bend and there is another added cost for the correct tools.
why no aluminum?
and there are some places who do prebent tubing correctly...
and a bender only costs 10 bucks...
Really for the reason same reason you said no rubber.. Alum is soft and I can see a slip of a jack, or rock or something crushing it. Need more then a bender for a good one and a flaring tool. Just wonder how rubber holds up on newer cars seems to work ok.
NHRA, 1 foot of rubber. An braided; expensive, and fittings are higher. Between Summit and Jegs, it cost me over $150 to run a braided line, on a 70 duster.
Whats wrong with aluminum? I run aluminum on the street. Anyway, remember you can only run 1' of rubber line on some drag strips if you plan on doing that.
