[FOR SALE] Selling a new, never used MOPAR Performance EFI kit for magnum engines
lapenskie
Member
BC, Canada
Rating - 0%
0   0   0
P5153590ATX
Discontinued high performance EFI package. Comes with everything to convert any high performance magnum engine to EFI. This kit is designed for a performance goal of 380+ HP. It will work with hydraulic 3 speed transmissions like 904 or 727, or 46 RE Automatic. The computer is not programmed for manual transmissions.
Comes with:
Wiring harness / Mopar PCM pretuned for 380 + HP application.
Fuel Rails
Injectors
Electric Fuel Pump and regulator
4 Bbl M1 intake
4 Bbl 1000 cfm throttle body w spacer
Distributor, Cap, Rotor, Coil, Plug wires
All sensors
All gaskets
All mounting and fuel hardware
Everything is new. Never installed.
Asking $2100 obo
P5153590ATX
Comes with:
Fuel Rails
Injectors
4 Bbl M1 intake
4 Bbl 1000 com throttle body w spacer
All sensors
All gaskets
Asking $2200 obo
Any idea if this is OBD1 or OBD2 based?
Pics of Wiring harness and JTEC.
If you are building and don't want to tune. It is programmed for 288/292 duration, .501/513 lift, 108 lobe separation running on 91 octane.
The injectiors are P56027872 and are 32lbs at 55 psi, the pump supplies 52 psi +/- 2 psi.
