I have for sale a set of 16 used SB Crane aluminum roller tip rocker arms, adjusters, MP chrome hardened shafts and the MP hold down hardware blocks. We had this on a mild bracket engine for a while then decided to put the car back on the street using the OEM design rocker setup. When we got these rockers, they weren’t a complete set, so we got other good used ones to make the complete set. The original ones have a smaller radius where the adjuster locking nut goes while the other ones have a larger radius. I guess Crane realized that it was a real PITA tightening the lock nut with the smaller radius. What we did was use taller nuts on all of them and that made it much easier to tighten. All the rocker arms are the same 1.5 ratio, but several were made later. Some scratches and wear marks but no issues at all with any of these parts. I would like to get $300.00 for the complete rocker setup plus the shipping. For an additional $50.00, if purchased together, I have a set of ball/cup pushrods that were used for the hydraulic lifter application. They measure approximately 7.25” and have a 5/16” diameter.
Ken
Edison, NJ
Ken
Edison, NJ
