sportfury62
New Member
727 tranny with shift kit/440 engine, at full throttle won't shift to 3rd unless I back off on throttle, adjustments don't change anything
He only tried adjusting linkage and told me it probably needed a new shift kit! $$. Going to take it to a different guy that's more knowledgeable and honest! Thanks for all the info everyone.ok, that is helpful. No real change in the car setup between working and not working. Was working ok after the shift kit but not anymore.
You say that the shop tried adjusting. Did they just adjust the linkage at the carburetor or did they drop the pan and lower the pressure adjustment in the valve body? Or something else?
Dumb question perhaps but did you check the fluid level with the car in Neutral and warmed up? Low fluid will cause what you're seeing.
It is possible that the governor is sticking in the bore. Sounds like you're already working with a shop. The trans shop could put pressure gauges to it and verify things using the FSM up on mymopar which would validate a sticking governor.
