[WANTED] shift tube supports
clementine
Flight risk
Emerald city
Are these re popped? 1967 barracuda manual steering column. floor shift. The inner shaft is hitting the inner tube. These pop through the 'mesh' part of the outer tube mid shaft...ish.
Thanks FABO!!
Yes, there's a guy on FBBO or Dodgecharger.com that tooled up to produce them. Let me go try to find..
67 is a different animal, and I don't believe those will work with a 67 floor shift/manual column, it needs to be supported at the bottom.
They actually appear to be for column shift only, it's labeled shift tube support, no shifting with a tube with a floor shift or 4 speed.
Also, that thread is wrong, collapsible columns were a thing in 67.
Yeah, cheap enough I ordered a set up though. May have to massage them. Clementine LMP.
