wazoo64
What is the best way to dial in the b&m shifter? I think I am real close right now. I put the quicksillver in park and then had the trans as far as it would go toward park position. Then I connected the cable at both ends. Is it better to do this with Neutral or park?
Also, I ended up using an Art Carr shifter cable and modifiying to fit the b&M. Art Carr makes a way better cable then the B&M POS.
Thanks for any advice.
