If there is a difference it isn't by much , the shifter box might be at a slightly different angle. Make sure the shifter is adjusted properly.
Also remove the shift lever off the trans and make sure it shifts into gear like that , if it doesn't then there is a clash between parts inside the trans , loosen the side cover and move it up slightly and t should clear the clash of the reverse lever with the 1-2 lever .
