A single adjustable shock is a basic bolt in adjust height have at it. The double adjustable allows the same of a single but allows you to tune the shock to the track better. Example would be that if the track you're at has more left turns then right, you can stiffen up the right side a little to help get in and out of the left hand turns.
A single adjustable shock is more than most will use as far as tuning.....I looked at a stock pile of companies from Pen$ke's-Afco-RideTech-QA1 etc..with my Demon project. Ended up with a single adjustable from QA1 as the number$$ get crazy
Thanks RJ, thats what I have in the rear already, Speedway motors has a package deal for $400 for a set of QA1s with springs. Thats what Ill use as well.
Andrew
