[WANTED] Shogun Tic-Tok
http://www.frcracingparts.com/cart.php?m=product_detail&p=314
TIK-TOK is an electronically controlled switch, which will eliminate the manual operation or thermostatically controlled operation of turning on and off, of two separate electric items.
It was specifically designed for aftermarket cooling systems, wherein the electric driven water pumps and electric fans are presently controlled either by a thermostatic switch or manual switches.
TIK-TOK is designed with a built-in timer so as to sequence the on and off cycles of each item. TIK-TOK is approximately 2" x 3" x 1" high, with Velcro as a means of mounting, and has five wire hook-up.
Two wires will attach to the three position switch supplied. One wire to the water pump, one to the fan and one to the negative post on the battery.
An easier link to use: www.google.com
