hotrod68
- solid lifter 440 ball and cup push rods (1 odd ball but the same length) $30.00
- dist. adapter to put rb dist. into a low deck with hold down $25.00
- double roller t-chain and gears used $15.00
- 2 sets of 3.23 gears for a 489 case $35.00 EACH
-2 sets 8 3/4 shock plates $40.00 each set
- 11 inch backing plates bare $30.00
- Dana 60 adjustable snubber almost new $40.00
-tti 3.5 inch header collectors $15.00
-2 small u-joint course spline 1 large u-joint fine spline yokes $20.00 each
-aftermarket a body brake booster (not much use) 30.00
-moroso belt drive water pump kit $20.00 used
-187 bbm oil pan used $30.00
-699 bbm oil pan used $30.00
Dutchman panel 67-69 cuda notchback new $50.00 (All parts plus shipping from 55940)
