Shoulder belts - roll bar?
Jim64
Escondido, CA
I'm planning to install a basic roll bar in my '64 Barracuda. I'd like to have shoulder belts in the car, and I think the upper mount should be attached to the roll bar. Have any of you done this? If so I'd like to know where you got your shoulder belts, and pictures would be a bonus! Thanks.
There is usually 1 or 2 tabs on the crossbar in the main hoop to mount the shoulder harness ends. NHRA belts are only good for 2 years so you may be able to find one or a pair of used ones to use.
I always used a V-style shoulder belt using a 1/2" Grade 8 one bolt mount for my application which went through a "box" added to the bar behind the seat.
DO NOT drill a mounting hole through the roll bar. Weld s tsb or box to it instead.
You can also get wrap around belts for the shoulders,that is what I am using.
Make sure the cross bar is in the proper location for shoulder belt recommended angle.
