mullinax95
I got my new A-body shroud today and have a question. The fan opening on the shroud is 19 3/4" in diameter and my fan is a 18" steel clutch fan. What is the correct fan for this size shroud?
With the 18" fan I would have 3/4" space between the shroud and fan. I have a torque strap that helps limit the movement of the motor but was curious to know do I need a smaller fan? The guy at Mancini says that the shroud fits a 16" before I bought it. I figured I would just by a fan to fit the shroud. However when I got the shroud in hand I find out that the opening is large enough for my fan but wasn't sure about it. Also larger the fan the more air it will move ... right?
