Side window Guides
71Duster
Alberta Canada
Rating - 0%
0   0   0
When I had the door apart to put the mirrors on my 71 Duster I lubed up all my tracks but he passanger window still screamed going down.
I found that at the top of the door there is a rubber bumper covered in felt that slides like a boot onto an L shaped bracket that keep the glass stabilized and from rattleing. My issue is the boot is worn out right through the rubber.
Called a few places and no one makes it.
Take a picture of it and post it up. I'll bet someone has one lying around. I might also but it would be awhile before I could get over to the garage to look.
This is the bracket it's on, the bolt is removed through a hole underneath the Duster emblem on the door. The rubber I taped up to keep it from scratching my glass.
Get a sheet of felt and a tube of contact cement at Wal-Mart. Cut and glue a small piece of felt to replace the one that is worn out.
Might be worth a try,
Jerry
