signs of a bad steering box or ps pump?
KramerSwinger70
70 Dart Swinger360
Rohnert Park, CA
so for a while now ive noticed an odd griding sound when i trun my wheel all the way (left or right) when i take sharps turns and such. i thot at 1st it was somthin like the tires rubbin on the body but theres no signs or rubbing. could my steering box or ps pump bein going bad?
You have a seperate belt for the power steering pump. By removing it the steering will become much harder (two hands), but you will take the pump out of the equation. If the noise goes away, it's the pump. By the way, when you "turn the wheel all the way" you aren't holding it against the stops are you? That pump will complain (make noise) if you do that. Try backing off an inch.
