Similar to SUPERSIX intake manifold?
Its a good manifold but not really made for the street. You MUST use headers (or Dutra Duals???), 350cfm carb, etc.In order to use this correctly you will need to do some port work and larger valves on you head.
JMHO
Frank
JMHO
Frank
Do you know of any slant six preformance intake manifolds that can be used on the street? I've been looking at the HYPERPAK manifold from clifford preformance. But i feel that that is just a little to much. Also the SuperSix setup, but i have tons of trouble finding those intakes
Check out the aussie Hurricane manifold always wanted to put one on my Fury.
do you know of any slant six preformance intake manifolds that can be used on the street? I've been looking at the hyperpak manifold from clifford preformance. But i feel that that is just a little to much. Also the supersix setup, but i have tons of trouble finding those intakes
i have a aluminum 2 barrel you can have for 20 bucks plus shipping. Tried to polish. Looks like hell but....... The heat area has been welded close. Good manifold.
You can get a small assortment of intake manifolds from Australia.
Below is a link to the mob that sell them.
http://www.aussiespeed.com/index.ph...n=com_virtuemart&Itemid=23&vmcchk=1&Itemid=23
They aren't the same as a Hyperpak manifold, but they do work.
