GoodysGotaCuda
Mr. Goody
Got my Duster up n running now. The car has absolutely no brake pressure. Its a 74 Duster with Power Front Discs. Shes been sitting awhile, has brake fluid, no noticeable leaks.
Whats the first step you guys would take in troubleshooting this? Bleed the brakes? I pulled the drums before the car was running and i didnt see any signs of brake fluid.
Also, it very steadily drips power steering fluid only while it is running. Its kinda hard to trace but it looks like its coming from the backside of the steering box, any likely places I should look for the leak at around there? Other than the pump and lines, im not sure where any other fittings/seals are that would leak.
Thanks
-Mike
Thanks
-Mike
