I have a 1970 340 Duster, is there any problems installing a six pack setup with the factory hood. Clearance issues etc. or anything else I should know before installing it. Thanks
I have the same car, with a six pack setup, 3:91 rear gear , 4 speed, and it hits hard at around 2500rpm's to redline. Great cruisability around town on the center 2bbl,I absolutely love it, no better sound than all 6bbl's pulling open!! No hood interference issues,but you will need a 3 speed wiper motor, as the 2 speed motor will not allow your air cleaner to fit. An electric fuel pump is HIGHLY recommended.otherwise you will be cranking over for a couple of minutes refilling the evaporated fuel bowls of all 3 after a short heat-soak. You also might want to read up on this to set it all up http://www.mopar1.us/6barreltips.html
