74 DART'
Im having some trouble with my daily driver. 74 Dart 225 c.i. Has a Holley 1920 carb on it. Getting oil / blow-by into air cleaner. You can remove air cleaner with engine running and it will smoke from valve cover breather hose the whole time the engine is running. I don't notice any smoke from exhaust while driving and the back of the car doesn't seem to be covered with oil. Im having a misfire- rough running condition at times, mainly when engine is warm and im wondering if it could be a lean condition. I have an exhaust leak on the exhaust pipe just before the muffler and you can hear a popping misfire sound , sometimes while idling at a traffiic light or sometimes while driving down the road. You can also feel the engine misfire/ stumble, i can back off the throttle and most times it will stop misfiring. I have checked the spark plugs and most of them are very dark, not sure if its all fuel or oil on plugs. They due smell rich and so deos the exhaust when running. Sorry for the long post. If anyone has any ideas i would appreciate it. Thanks J.R.
