[FOR SALE] Slant 6 engine and transmission
440BelII
Darien Center, New York
Rating - 88.9%
8   1   0
I picked up a '73 Duster with a slant 6 drivetrain. I'm planning on pulling this and replacing it with a V8 setup. I did here it fire so it's a runable drivetrain if someone needs one. I'll also be getting rid of the 7 1/4 rearend as well. Motor and trans are still in car will have to pull. I'm not sure if this is the original motor for this car, it has a 2 barrel intake and carb on it. I'll start out at $250 for motor and trans/make offer, or trade for other Mopar related items. I'm located outside of Buffalo, NY. Pickup only.
I would be interested in the intake and carb if you decide to part it out.
Put me second in line if you decide to part out the engine. Id like the carb, choke, intake, air cleaner, and kick down linkage.
