[FOR SALE] Slant 6 short block parts cheep.
couper 340
maryland
1976 Plymouth slant 6 short block locked up from sitting 1999 to 2021 moisture damage.
IF you see a part on this you can use let me know most parts $5 to $10.00 plus shipping oil pan $20.00 if you need a piston or rod i will try to get it out .
I've got one that I'm using for a science project, and it was locked up also. It wasn't the pistons that had mine stuck.....it was the rusty cam and lifters. If you take the timing chain off, the bottom end might turn so you can get it apart. Good luck with the sale. :)
yes lifters are stuck to.
also have flex plate , fuel pump looks new but i would have to test it $3.00 / motor mounts / fan pulley /crank pulley/ oil dip stick with tube/ timing cover /oil pump/
How much for the Distributor shipped to 34209
just sold distributor today
I need a dipstick! Not pictured, but I also need a throttle return spring(s). Thanks, Pete
pete please let me know if you don't want it and i will pass it on . Thanks joe
Hi Joe, I am still interested in the dipstick/tube, and the throttle return springs, if you have them. Please let me know the shipping and how to pay you. Thank you, Pete
