Slant Six Aluminum 4 speed bellhousing-press plate-disc-flywheel-large collar
62lancer
Active Member
Located in Boise, Idaho---I have 3 Slant Six 4 Speed Bellhousings with flywheel, pressure plate and disc--all are used but serviceable. The Bell housings are the later aluminum type with the large collar opening-----$200 for each set. I have one of these in my 62 Lancer with an early trunion A-833. I had a friend make an adapter to center the small collar in the large hole--works perfectly.
This would probably go better in the for sale section. It will probably be deleted from here.
