[FOR SALE] Slant Six Billet Flywheel $250
MidnightSwinger
Woodland CA
Bolted to crank and clutch installed, but never run. This is for the small register crank pre ‘68. You can have it machined for the larger crank register if you need.
$250 located in Woodland CA 95695
RAM Clutches 1580A RAM Billet Steel Flywheels | Summit Racing
What pressure plate drill patterns are on this flywheel? it looks like more than one possibly.
I would assume the Borg & Beck 9 1/2" - 10" pattern is there, but what would the other one be?
Thank you.
Thank you.
Itll accept the stock style PP and also what I believe is a Ford PP bolt pattern that the Ram 9.5” clutches use.
