[FOR SALE] Slant Six Camshaft
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
After much figuring with the slide rule and the abacus, I have determined this camshaft is too small for my build, so I am going to sell it. It's a solid flat tappet from Hughes Engines.
It is this one:
Hughes Engines
I am going to have too much static compression to run this cam so I need a different one. I've only had it out of the box twice. It's never been in a block. Located in middle Georgia, I will take 150 shipped to the lower 48.
Thanks.
This cam will work fine if your using stock type slant six pistons. It will not work for my build because I am using the long 198 rods and 2.2 non turbo pistons. It would also work if you are using the long rods but with the turbo pistons.
Still for sale.
