Slantsix64
Let’s see if this helps that fuel bowl.
I actually have a wooden spacer above the shield! Those insulators are a mustIf you have the space, these work wonders and especially well combined with the aluminum shield.
https://www.amazon.com/Edelbrock-9266-Heat-Insulator-Gasket/dp/B00062YBPM?tag=fabo03-20
I feel like the four barrels do this more that the stock one barrel of factory two barrel. It’s just that design of the exhaust manifold under the intake.Is this a common problem with the 4-barrel conversion or is it more because of the double-pumper, dual bowl setup you have? I assume the bowl closest to the valve cover is your boiler.
I had the boiling issues with either orientation of the carb.So your carb is 90 degree rotated compared to Slantsix64 and appears to have the edelbrock design vs. the Holley dual bowl design. Did you also see fuel boiling problems before the heat shield install? I like your layout better for throttle purposes but where is your tranny kickdown (or is it 4 speed?)?
Just learning from your expereince.
RGAZ
That throttle cable bracket you have, did you wake that?
Yes. It was a manual valve body tranny so no kick down.That throttle cable bracket you have, did you wake that?
I need something like that the one I have doesn’t return thre throttle sometimes unless I put a heavy spring.Yes. It was a manual valve body tranny so no kick down.
I used the Edelbrock thick 9266 divided or the 12410 open base gasket.Did you also see fuel boiling problems before the heat shield install?
