Slant six identification experts: How about this?
Slant 6 Engines
  1. cruiser
    cruiser Well-Known Member
    133
    107
    Feb 26, 2016
    Minneapolis
    Local Time:
    10:57 AM
    Hi All: Are you an expert on what the numbers molded into a slant six engine block mean? Here's what I've got on the left side of my engine block:
    2806830 6
    132 4 BH
    AAWJ
    4G251846 (stamped on a pad on upper right rear of block)
    Any and all ideas are welcome. Thanks!
  2. Alaskan_TA
    Alaskan_TA Well-Known Member
    5,637
    3931
    Nov 12, 2004
    PA
    Local Time:
    11:57 AM
    4G so it is from a car built for the 1974 model year at the St. Louis plant.
    They were making A and B bodies that year.
  3. bcschief
    bcschief Well-Known Member
    561
    156
    Feb 23, 2010
    Crescent City Florida
    Local Time:
    11:57 AM
    The 4G251846 is a partial VIN number see if it matches your car if it does it's the original engine. Look under the alternator bracket and read the numbers on the edge of the deck and post them.
  4. J Glenn
    J Glenn FABO Gold Member FABO Gold Member
    204
    72
    Sep 6, 2017
    Minneapolis
    Local Time:
    9:57 AM
    FYI: It's junk. You should sell that engine to me!
  5. cruiser
    133
    107
    Feb 26, 2016
    Minneapolis
    Local Time:
    10:57 AM
    bschief: I checked and couldn't find any numbers under the alternator bracket. I did find some markings molded into the block under the fuel pump. The first was an arrow pointing to the numbers 1 - 2 - 3 , and the arrow was pointed at the number 2. To the rear of this was what looked like a clock symbol, with an arrow in it pointing to the four o'clock position. Any ideas?
  6. cruiser
    133
    107
    Feb 26, 2016
    Minneapolis
    Local Time:
    10:57 AM
    To J Glenn:
    Huh?
  7. J Glenn
    204
    72
    Sep 6, 2017
    Minneapolis
    Local Time:
    9:57 AM
    I've been looking for a /6 for two years and I never find them locally. So... you "upgrade" to a 318 and sell me your /6 ;-)
  8. bcschief
    561
    156
    Feb 23, 2010
    Local Time:
    11:57 AM
    2nd shift and 4pm was when it was cast. Look straight down at the top of the ignition coil the pad is behind the coil you may have to clean it off with brake clean to read it.
  9. cruiser
    133
    107
    Feb 26, 2016
    Minneapolis
    Local Time:
    10:57 AM
    bschief: What exactly is it that I'm looking for on this pad behind the coil?
  10. bcschief
    561
    156
    Feb 23, 2010
    Local Time:
    11:57 AM
  11. cruiser
    133
    107
    Feb 26, 2016
    Minneapolis
    Local Time:
    10:57 AM
    Okay, just found it. The pad below the right front top corner of the block, right under the cylinder head, says:
    W 225 681
    So what does this mean?
  12. bcschief
    561
    156
    Feb 23, 2010
    Local Time:
    11:57 AM
    W= Windsor engine plant 225= displacement 681 should be a date code but it makes no sense look again and see if you missed a digit most likely before the 6
  13. cruiser
    133
    107
    Feb 26, 2016
    Minneapolis
    Local Time:
    10:57 AM
    You're right. The number is actually 4681. Whaddya think?
  14. bcschief
    561
    156
    Feb 23, 2010
    Local Time:
    11:57 AM
    4681=Wednesday May 22 1974 on Chryslers 10,000 day calendar
  15. cruiser
    133
    107
    Feb 26, 2016
    Minneapolis
    Local Time:
    10:57 AM
    Got it, thanks. Any ideas as to what the "BH" and "AAWJ" mean?
  16. bcschief
    561
    156
    Feb 23, 2010
    Local Time:
    11:57 AM
    The BH blocks are the best forged crank blocks per Doug Dutra. He is a slant six guru and has even written a book on them. Here is a link to his book Amazon.com : slant six book
  17. bcschief
    561
    156
    Feb 23, 2010
    Local Time:
    11:57 AM
    Does that partial vin match you cars vin ? The aawj I am not sure.
  18. cruiser
    133
    107
    Feb 26, 2016
    Minneapolis
    Local Time:
    10:57 AM
    It does not match my car. The tranny is numbers matching, but the engine isn't. The engine is a parts store replacement engine installed in 1988. It is a 1974 block, but had an incorrect 1976 head on it, which I changed out for the correct head. It runs really well, though.
