[WANTED] Slant Six power steering pulley
360Scamp
Mopar or No Car
Herrin, IL
hey guys I’m looking for a power steering pulley for my Slant Six. I recently added power steering and the pulley is set back too far and I need this kind of pulley in order to run power steering. Please let me know what you have lying around. I also have this pulleyin the 2nd pic to trade if anyone would be interested.
Thanks so much in advance
Well the pump came off of a 85 dodge D150 and I put it on my 82 dodge D150. I have hit up all my forums for Mopar parts. I just need that pulley pictured.
But the pic is from my buddies 73 Scamp
I have a 65 or 66 slant in the back garage that has a bad housing (the nipple is broke off for the return line), but has the pulley... But i'm not sure if it will work on an 80's vintage truck....
Could you take a pic of the pulley so I can see what it looks like. I’m willing to give anything a try at this point.
I have a Saginaw pump I believe. I always get the names and style confused
My pumps different and it don’t think it sticks out enough to line up with my harmonic balancer.
Does that one bolt on or press on?
I have searched all over the internet as well as slantsix.org with no luck.
Thanks for your help guys maybe someone else will chime in here soon
If I can find the pic I posted first, I will home the hole out to fit my shaft if it’s too small and try to make it work
The 1st pic looks like it tightens down with a set screw but I’m not sure
No there are only to types, press on or those that have a keyed shaft and are held on by a nut. Yours is a press type, requires a special tool to remove it and another to pull it on your pump shaft.
It looks like a shallow hex on the piece in front of the pulley, so I believe it's threaded/bolt on...
Why not do a search on car-part.com and see if there's one near you??? It's a national data base of salvage yard parts for sale...
Car-Part.com--Used Auto Parts Market
I just sent you a PM with a link to pics and info, i have a truck pump with pulley for under $10 Let me know
