rustytoolss
Has anyone/ or can a Slapstik shifter be use/or modified to work with the A500/A518 ?
OK, but what I'm asking is if a Slapstik shifter can be used on the A500/A518 overdrive transmissions ? With it bolt right up ? or what kind of mods need to be made ?U dont need to do anything as the od is mechanical and or electric. Has 3 shift spots same as a 727 or 904. Kim
Geometry... If anything. I think like stated there may be a button like my Durango to un-activate it. What I do in those situations is since I'll have the tranny out and since I'll have a new shifter I get them working on the bench correctly so when I install them it's just about hooking it up not finding the geometry while crawling underneath the car.OK, but what I'm asking is if a Slapstik shifter can be used on the A500/A518 overdrive transmissions ? With it bolt right up ? or what kind of mods need to be made ?
If you are referring to an aftermarket shifter which uses a cable it will be no problem. @TrailBeast Is a great resource as he used a B&M quicksilver and added two switches 1. for the OD and 1. for the lockup.
