What slave cylinder are people using in their pieced together hydraulic clutch setups? I am going to use a master cylinder from a late 80's Ram truck, it has a 7/8" bore.
If you are still using the factory clutch fork, most guys are using either the Speedway, Wilwood or Howe pull type that bolts to one of the trans mount bolts with a bracket.
