Mopar92
What’s about the most you guys feel comfortable with the yoke flat surface to the boot seal?
But too much out is hard on the tailshaft bushing too.I have measured the movement on a couple cars (stock suspensions) and they never moved more than 1/2". I also measured my 68 Cuda with Caltrac springs and they didn't move more than 1/2" in and out either so you should be fine at 1". Driveshaft makers typically use the 1" rule so there is very little chance it'll bottom out and wreck your trans. They don't want to be liable for that
