Slip yoke
sireland67
WV
Does anybody have an extra slip yoke for a 727 or 4-speed with 30 spline which uses the 7290 universal joint.
Thanks
Is that the small U joint? If it is, I have one. I need to verify I don't need it first. I will post back in the morning...if the small joint is what you need.
FYI
7260 is the small one 26 or 30 spline
7290 is the medium u-joint 30 spline
1350 is the large one 30 spline
FYI
Yeah. I knew 1350 was the big un but I wasnt gonna argue. I just couldnt remember the other numbers.
Stroker,
I could still use the small one as long as it has 30 splines, I just need it to plug the back of a rebuilt tranny, while it goes in storage.
Thanks
