zac_F71
I'm located in MN but willing to meet anyone in the cities with any of the listed parts - short of smaller stuff I'm willing to ship..
Parting out my 383 big block turbo build to go 5.7 hemi EFI turbo.. I have a 3,000 score on eBay - I do not sell junk unless it is posted junk, and do not rip people off. cash in person, paypal, or postal money order is preferred payments
67 383 from new yorker derby car ran when pulled from car needs machine work torn down currently - still STD bore $400 w/ stock rods/pistons/crank/ small valve heads/ little parts - will not ship
71 "346" 440 unported heads need 1 plug hole fixed have good aftermarket springs off running 440 $Getting fixed and checked - will update when I know final costs - OR $200 shipped as is.. meet up price $150
Edelbrock Torker 383 low rise single plane intake has heli-coils in all 8 carb stud holes, 1 is weak but holding - studs are new 2.5" tall - would need a 1" spacer to use these studs $150
ARP main studs for small or big block - installed never torqued $75
Big block Milodon 8qt oil pan and pick up $150 used but good
Big block black wrinkle MP valve covers used in great shape $80
Big block A727 has a refresh, transgo shift kit, and 4.2 band lever in it, 0 miles fresh from the shop $500 will not ship
stock oil pan cleaned ready to blasted/paint $50
stock valve covers stripped/cleaned - no broken tabs $50
Heddman B body headers kink in 1 tube from being in a full frame wagon race car - only scratches from install other wise - $120 - prefer not to ship these
NIP trans dapt big block swap mounts using SBM K member $65 (same as Schumacher)
used unmachined stock forged 440 crank $150 - prefer not to ship this as well came from SharaDons inventory
1979 360 block and stock crank $100 - bored .030", cleaned but should be checked by a shop - new frost plugs installed and I would torque plate bore it to .040" just to be safe that the bores are round
71 225 slant 6/A904 setup out of my Demon - runs and trans works great $200 - many NEW parts in it, comes with lots - intake/exhaust mani, carb(stock 1bbl)!
Slant 6 a body K member $make offer
Stock a body lower control arms - missing torsion bar tensioner bolts $make offer
More to come as I figure out the 5.7 swap!
![](http://i295.photobucket.com/albums/mm133/1fast96gti/A%20big%20block%20parts_zpsxpfde8ts.jpg)
![](http://i295.photobucket.com/albums/mm133/1fast96gti/Demon%2027_zpsjou8bkuj.jpg)
