67dodgedartconv
I have a 67 Dart that was a 273 2 barrel car from the factory. I put in a 318 with 360 heads and factory 360 4 barrel manifold. I bought an aftermarket replacement 340 throttle cable holder (bracket) and installed it. I bought an aftermarket replacement 340 throttle cable and it is several inches too long. I mounted a street demon (thermoquad replacement type) carb. I think the cable length was listed as 24 inches which was the shortest one listed, think I got it from Mancini. When I hook the end to the throttle lever stud I get a large "s" bend in the cable which causes it to bind badly. I could not reuse my 2 barrel throttle because it was frayed. The carb butterflies open freely with the cable removed. What is everyone using for a correct length cable? Mine may be 4 to 6 inches too long?
