femtnmax
Send me a PM for offers or if you have any questions. My location is Bozeman MT 59715. Thanks for looking.
Milodon 8 quart oil pan # 30940 for 360 V8 with Milodon pickup tube #18345
http://www.summitracing.com/parts/mil-30940
http://www.summitracing.com/parts/mil-18345/overview/
Never damaged, no internal changes, skid plate added to bottom.
Total cost thru Summit is $294.90, asking $175 OBO.
Edelbrock Performer RPM Air Gap intake manifold #7577
http://www.summitracing.com/parts/edl-7577
Fits magnum cylinder heads. Modified to accept spread bore or square bore carburetors. No porting of runners, and no stripped threads. Includes new unused MR.Gasket intake manifold gasket set, new 180* thermostat and gasket, thermostat housing w/ bolts, and bypass hose to fit LA water pump.
Cost thru Summit is $299.95, asking $180 OBO.
A pair of Edelbrock Performer RPM assembled cylinder heads to fit the air gap intake manifold will also be up for sale as soon as I clean them up. Valve stem to guide clearance was checked and corrected as required prior to installing/running the heads. Intake ports have brass tubes installed to open up the port cross section. I ran different valve springs, but will be reinstalling the original Edel springs. They have ARP 7/16 rocker studs, but I can reinstall the original Edel studs if wanted. The heads have 3000 street miles on them using a mild street cam. Never overheated, no stripped threads. Also have 16 Comp Cam full roller rockers 1.6 ratio, and eight 1.65 ratio; all in excellent condition to fit the Edel heads along with 16 Comp pushrods.
I live above 5000 feet elevation, the air gap intake did not work well on cold days, and I needed more low end torque than the cylinder heads offered.
