[SOLD] small block bellhousing
khaley71
Maryland
Selling an aluminum small block bell housing for 4 speed trans. The number on the bell is 2892482. My books state this is a 10 1/2 inch bell that is correct for 69 thru 71 A,B,C and E-bodys. I cant find any cracks the lower right bolt hole will need a heli coil. The first 4 or 5 threads in upper right hole are stripped but the rest of the threads in the hole are fine. You could run it as is or heli coil that one also. I ran a tap threw the rest of the holes and the threads are fine. Over all needs a good cleaning its pretty dirty. Asking $140 shipped in the lower 48. Locate in Maryland
