billytuffnuts
Basically brand new, installed it on my old (used) oil pump drive shaft for my 360 and installed it in the engine, spun the engine around a few times by hand and pulled it out as I switched to a roller cam that had a cast gear pressed on.
I know the actual gear will fit big block oil pump drive shafts but I don't know whether or not the actual shaft will fit anything other than a small block. If not you could remove it and have it installed on yours. .484 shaft diameter if I remember correctly.
Looking for $30+shipping
