12many
Cam plate, chain oiler, 3 mounting bolts, Fuel pump eccentric, factory bolt w/bellville washer, cupped washer, distributor holdown with extra bolts (not sure which is correct length), factory damper bolt and thick washer, oil filter plate and fitting. All wire wheeled, all threads and bolt heads, cam thrust plate, eccentric surfaces in great shape, no wear. $60 shipped.
