[Found!] Small block Chevy used 1.6 ratio roller rockers and poly locks
physixx
Edison, NJ
For our Chevy friends, I have for sale a set of 16 used small block Chevy aluminum roller rocker arms with poly locks. These rocker arms are the 1.6 ratio design, have been milled for clearance for use with larger diameter valve springs and are designed for use with 7/16” diameter head studs. From the research that I did, they look like the Crane rollerized rockers but not 100% positive. They don’t appear to have any issues except that 2 of them have some scuffing on one side of the roller tip end of the main body as can be seen in the pic. Not sure what that’s about. I would like to get $125.00 for everything plus the shipping.
Edison, NJ
