Backtobasics
Am I missing a piece of the puzzle?
Small block mopar. Scenerio is engine rebuild, so distributor has been removed, timing set installed, engine rotated around, etc. Magnum fuel injected engine in 97 Ram.
KNOWN IDEAS... Drive gear has hex at bottom. Drive gear can slid into place any which way it chooses, as long as it engages the oil pump. Drive gear has screwdriver slot at top to recieve distributor. Distributor can go into drive gear one way or the other, one is right, the other is 180 degrees out.
Here is where I am at: 97 Ram 360 engine. Engine swap. Inital start up, truck runs, but feels like timing is off. Rotate body of distributor, and it smoothes out, runs. We button up all the "engine swap stuff" and it is good to go.
I am wanting to fine tune distributor position as it is set by ear. I am told that timing is now under control of the computer, and the function of the distributor (outside of passing spark via cap and rotor to plug wires) is to "sync" for fuel delivery. Distributor provides some reference for computer for fuel delivery? (I would think it would use the crankshaft position sensor).
Chilton's says to bring to intake stroke at TDC. Rotor should be point at a groove in the distributor housing. I tried to rotate the distributor body to make rotor match notch, and it does not line up perfectly. Distributor body bumps firmly some type of internal "stop". Tighten it all, and it pops and backfires.
This AM, I loosen distributor body, and rotate notch in body (from 9 o'clock, to 10 o'clock), and truck runs better, no CHECK ENGINE light, no popping.
Question is this: if the rotor position is determined by the oil pump drive gear, and the drive gear can go in any way it wants (not keyed or locked to a certain position relevant to camshaft position), how can the rotor be used as a reference at all?
Said another way, the book showed the rotor pointing at 9 o'clock. My rotor was at 9 o'clock. I could not rotate the body of the distributor to make the notch match the tip of the rotor as the images shows.
