1990 Small block LA heads. Heads were set up for stock roller cam and have only idle run time, no miles. Selling because I got a good deal on aluminum heads. $400 Edelbrock Performer aluminum intake manifold. Will fit LA 273-360. $150 Will separate. Thank you.
I don't think there is a flat rate box that they will fit in. Did you want the heads and the manifold?
